Errant callout tags
Errant callout tags
Sahay_R
Mentor Mentor
Message 1 of 27
Errant callout tags
Sahay_R
I have a callout tag that behaves beautifully, with the middle horizontal line staying horizontal - but in this particular project, the horizontal line turns vertical. When I hover over it - or view it in wireframe, I can see a horizontal as well as a vertical line. The horizontal line, BTW, is from the two semicircular masking regions that have been created.
Has anyone run into this before? I have checked the family, recreated from an OOTB family, done everything - but the horizontal line ALWAYS comes in vertical. But when I take the same family into another - or a new - project, it behaves flawlessly!
PS - also - if I edit and reload the family, the view does not show the edited family, it only shows the old family. HELP!!
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
Replies (26)
Message 2 of 27
Make sure the View Type is using the correct Symbol family.
Message 3 of 27
Hiya Rina. Can you post the family? Maybe we can use the rubber hose on it to get it to cooperate.  Smiley Wink
Message 4 of 27
Sahay_R
@ToanDN - yes it is. But the project still insists on showing the old family. When I hover over the tag, the new family lights up under the old family.
 @barthbradley - you got it. It really looks like there is something in the project that is creating the problem, but go ahead - have fun
Rina Sahay
Message 5 of 27
Can you share a screenshot of the Callout View Type properties, and a screenshot of the Symbol family type listed in the Browser?
Message 6 of 27
Sahay_R
Rina Sahay
Message 7 of 27
This family is only for Plan/Detail Callouts. What you show is a section Callout, it must be using a different symbol family.
Open a proper project, edit the view type and see what symbol is used for View type's section tag, then load that family in this project and use it for the Drafting view type's section tag.
Message 8 of 27
Change Family  from Callout Head Category to Section Mark Category.
Message 9 of 27
Sahay_R
So I have been editing the wrong family altogether? In that case, here is the family for the correct bubble - (and it still looks bad in the view)
Rina Sahay
Message 10 of 27
Try this.  But I would advise again using a masking region in a Section mark family.
Message 11 of 27
Sahay_R
Yep. Because when I edited the family that I sent you, then it changed all my nice and polite building sections too!
Rina Sahay
Message 12 of 27
Sahay_R
@ToanDN - remind me - we use the dashed text line trick to keep the horizontal line horizontal right? Or is it the other way around? The main problem with that trick is that it does not look correct on the sheet
Also - the family you sent me - turned vertical again...
Rina Sahay
Message 13 of 27
Why don't you make the Masking region invisible and trace the boundary with visible detail lines?
Message 14 of 27
Because they are all using the same family for their Section mark symbol. The mask will rotate following the section direction and there is no draw order to send it behind the horizontal line. That's why when people need a mask, they have to use a string of text ______ for the horizontal line in lieu of a symbolic line. Text always stay on top so it isn't masked by the masking region.
By the way, what I sent you should work for horizontal and vertical sections only.  The reason it doesn't work for you because you open the family from my file but did not close the existing family so you essentially till in the same old family.  Close your existing family, then edit the family from my project to open it and load in your project and it should work.
Here is the family with text line.
Still, I would get rid of the masking region, or use a ______ text string for the line over a full circle mask, not two halves.
Message 15 of 27
Sahay_R
@ToanDN that's what I had started with - the text string that always stays horizontal - but it doesn't read correctly in plans.
@barthbradley - I think that is what I will end up doing.....
Rina Sahay
Message 16 of 27
How does it look incorrectly?  Can you show a pic?
Message 17 of 27
Sahay_R
@ToanDN - here you are. The dashes are obvious - also, not enough control over lineweight. This solution flew at my previous job, not here....
Rina Sahay
Message 18 of 27
That is because the text type you use is too small. You can play with it to get the matching graphic.
Message 19 of 27
Sahay_R
@ToanDN - so you would suggest using a really large text type to have maybe one dash cover the circle?
Rina Sahay
Message 20 of 27
huh???
...I'm on the edge my seat waiting for the response.
