Message 1 of 26
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I'm ok with the equal feature for simple situations but wondering if there is a down and dirty way to make dimensions between objects the same for differing sized objects.
I have a bank of storefront windows between different sized columns/ mulls and would like the distance BETWEEN the columns/ mulls to be the same. If I go center to center it will not work because the distance between the elements will be different.
I tried dimensioning face to face of "mull", locking the mull dimensions and then setting the equal parameter but that didn't work.
Hopefully there is a solution to this because I have to do this relatively frequently.
Anyone?
