Energy simulation requires internet access
I have a stable internet access and I am connected to the internet. I also checked posts on autodesk people suffering from the same problem and I tried the solutions mentioned but nothing worked for me. I also changed the computer and connected internet cable but the same problem
Any suggestions?
Sounds like a firewall.  Have you tried disabling?
You might also list what you tried already, as well as the Version of Revit you are using.
I disabled the firewall and the antivirus and I restart the program but nothing changed .. I am using Revit 2017 (educational account)..
I tried to
  • Close all Autodesk Applications
  • Clear user cache & history, in your browser
  • Check LAN Settings
  • I tried even to reduce the details in the file and convert it to conceptual model
  • I reduced the analytical space resolution/ analytical surface resolution
  • I removed the detailed elements in the material thermal properties
  • Under C:\ProgramData\Autodesk\ADUT, delete the ProdInd_UserInd.cur file
Thanks a lot.. I really appreciate your help.
Wow! You ran the gamut here.  The only thing you missed was to confirm if your Internet Access is working.
Kidding. Obviously, it is if you're posting here.  😉
hahahaha
brahim.elasri18
Hello
Did you get the soulution please ? I have same
