Energy analyze cannot process in revit 2018
Message 1 of 14
I'm a student doing the energy analyze in the Revit and I created a energy model.
When I click the generate, there was a alarm show up: 'There has been an unexpected problem. Unable to analyze'
Refer to the snipshot below.
Any experter can help me to solve it?
Replies (13)
Message 2 of 14
Post your file.
Message 3 of 14
MostafaElashmawy
Refer to below link for the causes. It's related to required permissions for Autodesk servers.
https://knowledge.autodesk.com/support/insight/troubleshooting/caas/sfdcarticles/sfdcarticles/Error-...
Mostafa Elashmawy
Message 4 of 14
RDAOU
Disable Anti-virus and firewall then try again...If you are logging in from university, you need to contact your network administrator or try again when you are home
Message 5 of 14
I disabled all the firewall and Anti-virus, still the same issue. I am using the education version, is it this problem?
Message 6 of 14
But how to do it? I don't know how to do it even I knew that need the permission
Message 7 of 14
Posted
Message 8 of 14
No issues here.  Analyses completes.
Message 9 of 14
How's your computer setting? Why I cannot analyze it? It's server problem or my computer setting issue? I'm in Singapore currently.
Message 10 of 14
MostafaElashmawy
check below link that discuss the same error.
https://knowledge.autodesk.com/support/revit-products/troubleshooting/caas/sfdcarticles/sfdcarticles...
Mostafa Elashmawy
Message 11 of 14
Trust me. It isn't brain surgery.  It's no more difficult than turning on a light swtich.  If @RDAOU 's suggestions didn't work, which are the most common reasons analyses fail,  I suspect you might be right. It's related to your license.  Contact Autodesk directly or your Autodesk reseller.  Sorry I couldn't be more helpful.
Message 12 of 14
Thanks for your helping.
Message 13 of 14
You welcome, buddy. Good luck.
Message 14 of 14
RDAOU
Have you considered upgrading to 2020.2? Energy Analysis does have a long history of fails with certain versions
If all fails try to fill out THIS FORM and toss it at Autodesk's team to resolve...
Apart from that...there is a Insight Energy Forum... you might probably want to post Energy related  issues there rather than here for someone to google a trial and error solution for you
Good luck
