Title Block Property in Sheet Properties
1 ANTWORT 1
Nachricht 1 von 2
wr.marshall
603 Aufrufe, 1 Antwort
I am trying to create a Title block property that is only appearing in the sheet properties. If I select the sheet I cannot set the revision (via properties), however deselecting the sheet you can then see the custom revision parameter. How do I have this on the Title block Properties as opposed to Sheet Properties
Sheet Property Shows Rev
Sheet Properties showing RevSheet Properties showing Rev
Title Block Property does NOT show Rev
Title Block NOT showing RevTitle Block NOT showing Rev
1 ANTWORT 1
Nachricht 2 von 2
als Antwort auf: wr.marshall
You would need to put a label in the Titleblock that reads the same Shared Parameter that you added to the Sheet.
Steps..
1. In the Project: create a Project Parameter using a Shared Parameter and add it to Sheets
2. In the Titleblock: create a new label using the same Shared Parameter from Step 1. Reload Title block into Project.
3. Enter a Value for the Project Parameter/Shared Parameter that you placed on the Sheet.  Label in Titleblock will automatically populate with that Value.
