Elevation marker divider not rotating
jherrchz
Message 1 of 13
jherrchz
I have an elevation marker divider that doesn't rotate with the elevation. How can I make the divider rotate with the text?
Replies (12)
Message 2 of 13
You mean rotate it like 90-degrees? If so, use Rotate tool and manually rotate it.
Message 3 of 13
jherrchz
When I do that, it messes up the other elevation taq.
My section markers are working like supposed to. The elevation marker divider doesnt update when you rotate it to another view.
Message 4 of 13
What do you mean by "divider doesn't update"?
Post the File (rvt).
Message 5 of 13
jherrchz
the line inside the circle. It should be horizontal, not vertical..
Message 6 of 13
jherrchz
here is the rvt tag file
Message 7 of 13
Seems to work fine and dandy. Post your RVT.
Message 8 of 13
I'm alittle confused here. You posted a Callout (which works fine and dandy), but your thread is entitled "Elevation marker divider not rotating". What gives?
Message 9 of 13
jherrchz
Okay, the issue is the elevation markers. Do you see how the text doesnt rotate like it should. The left and right elevation marker has a vertical line inside the circle of the elevation marker instead of being horiz. The top and bottom marker is correct, the left and right has something acting weird.
Message 10 of 13
jherrchz
The section markers do display correctly. do you see how it rotates with the view orientation?
Message 11 of 13
You can't change that.  That is why the OOTB elevation marks don't have that line.  Keep the sheet number label in the circle, move the view number outside of the circle.
Message 12 of 13
azad.Nanva
you should have the different family or smart one.
like this one:
Message 13 of 13
I don't understand why you are trying to dumb down Revit.  An Elevation Marker is capable of calling out 4 views/directions in Revit. If you only want 1 view/direction called out, then use a Section Marker. If you don't want the tail and the cut line, then don't use them.
...is this, by any chance, about how the Views are organized in the Project Browser (e.g. grouping, sorting)?  If so, this can be solved for (and customized) fairly easily.
https://help.autodesk.com/view/RVT/2022/ENU/?guid=GUID-96F9CDB5-C46D-4597-943B-DF231E8EC688
