Items Appearing Above Cut Plane
1 ANTWORT 1
GELÖST
Nachricht 1 von 2
PhilvK
166 Aufrufe, 1 Antwort
I created a wall opening using the basic door opening family, and added trim and an arch above the opening. The arch trim is above the cut plane, but the arch trim still appears even thigh both the project and family's cut planes are set at mid-opening. Since I used a 'door' family, this shouldn't be happening, correct?
1 ANTWORT 1
Nachricht 2 von 2
als Antwort auf: PhilvK
Cuttable vs Non-Cuttable
Help | About Cuttable Families | Autodesk
