Elevation issues
4 REPLIES 4
jochia13
769 Views, 4 Replies
Elevation issues
In the East, West, South, and North Elevation view in Rivet my model shows as thin lines instead of the actual object. How can I fix this? I am working on a framing plan. The lumber columns represents the the thin lines but I want it to show the actual lumber.
4 REPLIES 4
in reply to: jochia13
change from Course to Medium or Fine Detail Level
...if that doesn't do it, then open the family, select geometry and look under it's "Visibility Settings". Both "Front/Back" and Left/Right" should have a checkmark.  And, if you want geometry shown in Course Views, then put a checkmark in "Course".  Understand that Detail Line also has Visibility Settings. You may want to set those differently as well.
jochia13
in reply to: barthbradley
In the East elevation view, it shows a portion of my model. In the North, South, and West elevation view, it shows the full portion I have created so far. How can I get the East elevation view to show full portion like the other views.
I have provide a screen of the East and North elevation view below to for clarity.
Turn off your Crop or Adjust it's size upwards.
...I'm talking about these controls on your View Properties
Good evening, I’m having the same problem but in the 2019 version and I’ve tried the solution but it still isn’t working. Please help.
Forma Design Contest
Technology Administrators
