Dynamo Family Instance with excel
killexy
killexy
Hello everybody ! Happy Holidays ! Please some can tell me, where I failed ??? ! Why I get the right answer with 1 ?? And why not with 2 ??Result.jpg
Accepted solutions (3)
RDAOU
The nodes seem perfectly ok and should work. I cannot really tell what's wrong just from the image...
I would need to look at the error message and at the lists being fed into "Point.ByCoordinates" Im guessing something in that list does not meet the input requirement. Try to switch the Boolean for preserveIndices (List.Clean) to False and run again.
killexy
The error message's <<There is a dash between the numbers !>> But when I check the excel file there is no hyphen !
RDAOU
Which Dynamo/Revit version are you using?
Want to  upload your Excel or CSV to check from my end?
killexy
Revit 2018 and dynamo 2.0.2
RDAOU
Checked the excel file and the numbers in are formatted/stored as text...Created a new sheet and converted all to numbers (See attached) … works perfectly ok
killexy
Thanks very much🙏 🙏 🙏 🙏
