MacBook Pro 2015 details are in the screenshots
Running Windows 10 on the latest version of parallels
dynamo plugin in revit 2021 will not render in 3d
I downloaded dynamo sandbox and it works fine... I need to use dynamo In revit for a university course, I would be super thankful for any help on how to resolve this.
things I have tried:
-Revit designated to run the high powered graphics card in windows set up
-Same thing on the mac side always use high powered graphics card
-In revit Options use hardware acceleration is deselected
-In the parallels settings I have "always use high performance graphics"
-Installed windows with bootcamp and encountered the same problem
I better advise discussing with dynamo forum. similar cases I have seen there before. they have some solution if still your issue not solved post in dynamo forum. we will continue from there.
Here something for you.
