dwg layer in different dwg linked file
Hi all,
I've a revit file with a lot of dwg linked file, every single dwg file has a layer with the same name that i have to hide in all linked dwg file.
Is it possible to do this thing in "one shot", without open every single link to hide the layer?
Luiscko
Yes is pretty easy you only need to create one script that recognize the CAD elements and then with the BIMorphnodes you have the node that you can select the layer that you like to override or hide in this particular view.
Luis Rodríguez
BIM Manager | Digital Transformation Lead
alt="EESignature" width="244" height="22">
Your Name
Encontraste util este post, compartelo y dale like para que llegue a mas personas como tú.
Si tu respuesta fue solucionada, te agradecemos que des click en el boton SOLUTION.
Sahay_R
@Anonymous You don't need to open every link to turn off the layer. Type VG (or open the View Template) . Check the checkbox for Show imported categories in view. Uncheck the layers you do now wish to see per the screenshot.
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
Hi Sahay,
thanks but i have a lot of dwg and i'm trying to find a faster solution than the traditional one.
Hi Luis,
thanks for reply, i'm pretty new of dynamo script i already tried the solution that you mentioned but probably i make some error and it doesn't work...i have to grow in dynamoSmiley Happy
