How to remove identity data parameter in Rooms ?
1 ANTWORT 1
Nachricht 1 von 2
2902 Aufrufe, 1 Antwort
Hi all,
I had a small query related to deleting or adding parameters in room name identity data.
While adding room tags I had renamed the rooms in the identity data name parameter . So on tagging the rooms it picks up the name which i assigned earlier . in this case i have assigned Room names like Room1 , room 2, and so on.
Pls refer screenshot 1.
When i open the edit color fill legend window , it shows all the room names parameters which must have been created earlier .  refer screenshot 2 .
Is there any way that i can delete the unnecessary name parameters , in this case (BEDROOM and Room ) .>>>???
Thanks in advance for the help.
1 ANTWORT 1
Nachricht 2 von 2
constantin.stroescu
als Antwort auf: Anonymous
First , you have to delete that rooms from schedules :
  1. open Room Schedule and activate Show to reveal the Not Placed Rooms
  2. select the Not Placed Rows and Delete them
  3. select Legend and Edit Scheme
  4. in Edit Scheme if you select Deleted rows the Minus  (-) sign is active now
  5. Click on (-) icon to delete the item from Edit Scheme
Constantin Stroescu
