Hi.
I have been making a Revit template for our office and today it was brought to my attention that using the duplicate view with detailing -option is not actually copying detail items such as detail lines and dimensions. I have been trying to figure out what could cause this but I am at a loss.
In this template I have modified some view settings and phasing options, but none of these settings should not be affecting the ability to copy with detailing. I have also modified the .ini-file to have all the correct directories but I don't think that would mess up this view duplication functionality.
Please if you have ever encountered an issue like this, I would appreciate any insight on how to fix this.
Solved by Naumanen. Go to Solution.
Post the RTE (or RVT based on the RTE) here and we'll take a look and see.
Hi.
The floor plan views must have been corrupted somehow. I deleted all the floor plan views from the template and created new ones with exactly the same settings and these new ones are working perfectly fine.
