drawing
5 REPLIES 5
soyhannnnn
384 Views, 5 Replies
drawing
Is there a way to merge line thickness? Sometimes when a filled region (drawn with pen 1) is over the contour of a filled region (drawn with pen 4), it blocks a part of the pen 4 lineweight.
What I would like is that the thicker line is always in front of the thinner line. Can this be done?
Labels (1)
5 REPLIES 5
in reply to: soyhannnnn
Like this?
Or like this?
Draw Order.
soyhannnnn
in reply to: barthbradley
12312312dsada.JPGwall column junction?
soyhannnnn
also? 
I was half-kidding around with you, but I know what you mean.  Not much you can do can really about it. Draw Order helps in some cases, but mostly not.  Best remedy is to look at the whole forest and not at the bark beetles on the trees.
soyhannnnn
 haha thanks
Forma Design Contest
