Drawing Sets Naming in project browser
kirsty_sweetmanGMHXD
How do I organise the sheets into separate drawing sets? I am unable to edit the project parameter to name the drawing sets.kirsty_sweetmanGMHXD_1-1722325095834.png
vitorbortoncello
Is it a text parameter?
Just create a browser organization to group and sort by "DrawingSet". Right click your project browser-browser organization-new-edit-grouping and sorting
https://help.autodesk.com/view/RVT/2022/ENU/?guid=GUID-FC5A8E35-BAC5-45AD-B6C2-B6B551417CF9
EDIT: if you are unable to edit the project parameter to name the drawing, create other project parameter that is a text type and associate it with sheets, then choose it to group and sort the sheets as mentioned before
A resposta te ajudou? Não esqueça de curtir e aceitar como solução!
Vitor Bortoncello | Arquiteto | BIM Manager
dAutodesk Certified Professional
handjonathan
Hi @kirsty_sweetmanGMHXD
Thanks a lot for posting your question to the forums!   Has the solution suggested by @vitorbortoncello helped with your issue?
We look forward to hearing back from you with more information so we can help you as a community! 
Jonathan Hand
Technical Marketing Manager | Construction
