@Anonymous wrote:
so is there any update? I didnt really understand the answer if there was one. Is there a solution which would look presentable? If i draw it in short segments then the ends wont connect to each other, if I draw it with detail lines, it looks horrible.
The closest solution (which took 1 and half hours) was to use detail lines, choose the elliptic pen and then draw ellipses, cut the other half of the ellipse away, and then mirroring the remaining half to the other side and moving them a bit. It still doesnt look like anything i would show to anybody.
The batt insulation tool only does straight segments. it will not do an arc segment like shown in the original image. If that look is important to you, you will need to do manually or maybe make some families that have the standard radius you use for that detail and put it in that way.
As I see it, I would probably just do it in straight segments and be done with it. I can't imagine a situation ever where drawing it like that would ever confuse someone to the point that it would matter.
In my mind the difference between those 2 details is not worth 90 minutes of billable time.
Jeff Hanson
Principal Content Experience Designer
Revit Help |
