In my north elevation, my outside wall is missing and not hidden and also east elevation my whole house is missing. How do I get them back onto the view?
Change your Far Clipping extents. Easiest way is to into Plan View, select the Marker, and use the shape handles to adjust the view bounding box.
...that's probably the worst explanation I've given. Go into Plan View and move the marker's cut plane away from the building. Betcha that's all it is. http://help.autodesk.com/view/RVT/2014/ENU/?guid=GUID-20C39905-4652-40F1-A7A7-C97EA6C3F32E
If what barhbradley said doesn't work check that you are not using phases.
-Edit Far Clipping to get walls to display.
-Check Phase of walls that are missing, Phase Filter setting for View,
-Check visibility for Worksets, Filters in View Properties
-See if any Masking Regions are in front of the walls in the elevation view
