Draw Order
Draw Order
76jsa
Message 1 of 12
Draw Order
76jsa
I need the area tags to be under the column and not graphicallu divide it.
Any help?
Replies (11)
Message 2 of 12
Can you be a little more specific?
Message 3 of 12
Those grey tone are not area tags.  Are they Areas or Rooms?
Message 4 of 12
76jsa
Sorry,
yes those are areas. Area tags are hidden.
I want those areas be under the columns - graphically.
thanks
Message 5 of 12
Are you using an Area color scheme? Change its location to background, not foreground.
Message 6 of 12
76jsa
I do. Where do I change it?
Message 7 of 12
76jsa
Where do I put it to the background?
Message 8 of 12
Open the view and look at its Properties, you see Color Scheme Location under Graphics?  Change it to Background.
Message 9 of 12
76jsa
I have it set as in background there in a teplate. but it is not under the wall or column 'hatch'.
Message 10 of 12
76jsa
Message 11 of 12
Do all the walls overlap the color? Change to Hidden Line Visual Style to verify. If so, then "Background" is set and working as it should.  Is this not what you were looking for?
Message 12 of 12
- Make sure the view is Hidden, Not Wireframe
- Make sure the model Categories (walls, columns, etc...) have no Transparency under Projection/Surface Transparency column
