Draw Beam Underneath Slab
dm0144
Message 1 of 10
dm0144
Hello everyone
How can I draw a beam underneath a slab without the need to draw level additionally on the desired height?
Replies (9)
Message 2 of 10
Change Z Offset Value.
Message 3 of 10
dm0144
When ever I would change the slab thickness, I would have to change the offset value for every beam on every floor. It's a lot of mannual work.
Any other way?
Message 4 of 10
You could associate all the Z Offsets Values to one Global Parameter.
Message 5 of 10
dm0144
Would you share  the steps, please?
Message 6 of 10
Message 7 of 10
dm0144
Thanks!
Message 8 of 10
Make sure Z Justification is set to "Top".
Message 9 of 10
WEC17
If you have a level already for the slab just use the same level and them you can also change your Start Level Offset and End level offset to a negative number. Ex. Slab is at Level 10'-0" and the thickness id 5" you beam is going o be at -5" at the seat level and end level offset. Select all visible in view and change them at ht ew same time.
Message 10 of 10
cbcarch
Once you have the Z axis set correctly,
Another added beneficial step could be to create a Beam System, so all your beams move together.
Cliff B. Collins
Registered Architect The Lamar Johnson Collaborative Architects-St. Louis, MO
