Double door help
Double door help
emilin_shahbaz
Message 1 of 8
Double door help
emilin_shahbaz
i'm trying to replicate the double doors in the laundry room(notice how they overlap) but am struggling yo find the specific door. Can anyone please help.
Replies (7)
Message 2 of 8
vitorbortoncello
Probably a constrain issue. If you post the family maybe we can help you more
A resposta te ajudou? Não esqueça de curtir e aceitar como solução!
Vitor Bortoncello | Arquiteto | BIM Manager
dAutodesk Certified Professional
Message 3 of 8
There is nothing wrong in that screenshot.  What do you see as a problem? Overlapping Swing Lines?
Message 4 of 8
Here; use this family in yours. It has a parametric swing.
P.S. This Family is also in Revit's  stock Content Library .
Message 5 of 8
kadmonkee
the door swing arc end point needs to be constrained to the door panel swing angle reference plane
If there is any information shared that is of value please give Kudos
If a solution is provided by any posters please mark them as Solved to benefit everyone else.
thank you
Message 6 of 8
handjonathan
Hi @emilin_shahbaz
Thanks a lot for posting your question to the forums!   Have the solutions suggested by @vitorbortoncello @barthbradley @kadmonkee helped with your issue?
We look forward to hearing back from you with more information so we can help you as a community! 
Jonathan Hand
Technical Marketing Manager | Construction
Message 7 of 8
emilin_shahbaz
I wanted to figure out how to get a double door but only change the angle of one of the doors, not both. So fully replicate it. The right door to be 90 degrees and the left to be a different angle. Thanks
Message 8 of 8
emilin_shahbaz
