Roof Scheduling
5 ANTWORTEN 5
Nachricht 1 von 6
dean_auger
409 Aufrufe, 5 Antworten
Roof Scheduling
Has anyone found a way to create a roof schedule that does not break down the roof into each of its assembled parts?
Essentially, I have created an insulated panel roof with a metal sheeting finished layer where they have been assembled as part of the 1 singular roof. When scheduled though, this single roof creates 2 lines, both of which calculate the area individually…yet then schedule as the combined thickness!!!
Tags (2)
5 ANTWORTEN 5
Nachricht 2 von 6
constantin.stroescu
als Antwort auf: dean_auger
I'm not sure I understood you well...
Is this what you want?
Constantin Stroescu
Nachricht 3 von 6
Create a roof schedule, not a roof material take-off schedule.
Or, use the roof material take-off schedule as you have, and filter out one of the materials.
Nachricht 4 von 6
dean_auger
I have created a roof schedule and isolated the roof that I am having the issue. As you can see it is modelled as one roof but scheduling as two. Yes I can filter out one or the other, but my question is there a better way, and why does each of them show a thickness of 135?
Schedule
Wall Assembly
Nachricht 5 von 6
alan.johnson7YLND
As @ToanDN said create a roof schedule, this will show it as one roof
Not a Roof Material take off
A material schedule will show the materials
And the thickness isn't an individual material thickness its an overall thickness
Nachricht 6 von 6
handjonathan
Hi @dean_auger
Thanks a lot for posting your question to the forums!   Has the solution suggested by @constantin.stroescu @ToanDN @alan.johnson7YLND helped with your issue?
We look forward to hearing back from you with more information so we can help you as a community! 
Jonathan Hand
Industry Community Manager | AEC (Architecture & Building)
