Thanks Steve, I'll try that.
Ak.
"Steve_Stafford" wrote in message
news:4229456.1094017603216.JavaMail.jive@jiveforum1.autodesk.com...
> There is not a command that will provide this organization of data. There
are a few ways you can approach this and accomplish comparable results.
I'll describe the one I like.
> Using phases you can establish a phase that exists before any others in
your project, call it Project Admin for example. Then place a wall and each
door and window type you will use in the project. Create the desired views
you need of these objects and use a phase filter to restrict the visible
objects to just the Project Admin phase. Then in the next phase demolish
each of them. Later in schedules you can filter easily ignore these "extra"
doors and windows using the phase settings for the schedule.
> I believe credit for this strategy belongs to Aaron Rumple, at least
that's who I picked it up from.
