Doors missing in linked Revit model
Berrys_Cooling_Drafter
Message 1 of 18
I am linking an architectural model into my project for some reason when I link the model the doors don't show the full door I can't figure out why can you please help m I need the architectural linked model to have everything show up as normal.
See attached picture
Replies (17)
Message 2 of 18
Yien_Chao
check the worksets, phases, options, view range...
Message 3 of 18
@Yien_Chao
View range is the same
how do I change the other settings you mentioned and do I do it while its linked or I need to do it before I link it
can you please show me how to do it
Message 4 of 18
hmunsell
what is the discipline of the view set to? please add a screenshot of your Properties window for each view.
Howard Munsell
Message 5 of 18
on all disciplines it doesn't change they all show the same missing parts of the door
Message 6 of 18
Maybe the level of detail, also check the visibility setings in the family editor
Message 7 of 18
TripleM-Dev.net
From what I can see the something from the door is visible, the 2 views have different detail levels, maybe the door family is built with different representation in the fine level.
Try setting you're view to Medium see if that solves it?
- Michel
Message 8 of 18
no that didn't help
Message 9 of 18
@hmunsell  see attached
Message 10 of 18
I've probably given you this cheat sheet before...
https://www.ideateinc.com/blog/2013/01/missing-something-in-revit-view-33
Message 11 of 18
hmunsell
couple things i notice off the bat is
  • the Original Model image has a View Template and is set to Coordination.
  • the Model Linked image does not have a View Template applied and is set to Mechanical.
id start by checking the VT settings. what happens if you make a New view based on the Ground Level with no VT in the Model Linked model?
Howard Munsell
Message 12 of 18
TripleM-Dev.net
Cut height seems different, see stairs and other elements.
Check in a section if the link is actually placed at the correct height!
Stairs cut symbol position differentStairs cut symbol position different
Message 13 of 18
@TripleM-Dev.net  that was just the view range I changed it now it looks the same by the stairs but the doors are still different see pic attached
Message 14 of 18
TripleM-Dev.net
Door swings missing, check the SubCategories of the doors category. if everything on.
Else check the doorfamily.
Message 15 of 18
hmunsell
is there any way you can upload the models?
Howard Munsell
Message 16 of 18
@hmunsell @TripleM-Dev.net @barthbradley @Anonymous @Yien_Chao
Detail lines were off the invisibility Graphics overrides
Thanks for all your help trying to solve my problem I greatly appreciate it great community I am learning a lot from you guys.
Message 17 of 18
Message 18 of 18
evick6X8CX
Community Visitor
Community Visitor
did you make this change on the door family, or was it in the view template?
