Guys, it s no big deal to spend extra 20 minutes to locate the door tags as neatly as we like to do for one project. I wonder is there a trick to take advantage of "tag all doors" and the tags automatically located perfectly at x location, as attached...
Solved by barthbradley. Go to Solution.
Yeah, that tiny shift makes all the difference in the world. 😉
p.s. you need to zoom in really tight to see it.
...or Tag All with a specified Leader/Length - say 1/256" - and then remove leaders.
I'm having way too much fun here. 😉
This tip is Awesome !!!
I have not tried this with doors that have imbedded ADA lines yet. Will see...
