Removing Names from Identity Data Section of Title Block
11 ANTWORTEN 11
GELÖST
Nachricht 1 von 12
andrewsmith20
1773 Aufrufe, 11 Antworten
I am trying to remove names from a revit template so these peoples names are auto populated into every document. Any thoughts?
11 ANTWORTEN 11
Nachricht 2 von 12
David_W_Koch
als Antwort auf: andrewsmith20
Not sure exactly what you are trying to do here.  If your template file has specific people's names entered for one or more parameters and you do not want that, can you not open the template file (as a template file), delete the unwanted names and then save the template file?
David Koch
AutoCAD Architecture and Revit User
Blog | LinkedIn
Nachricht 3 von 12
andrewsmith20
als Antwort auf: David_W_Koch
I cannot find where these name are populating from.
Nachricht 4 von 12
David_W_Koch
They do not populate from anywhere.  They are instance parameters of each Sheet.  You would need to go to each Sheet and change any unwanted values.  You can select multiple Sheets in the Project Browser, and then change the values for those instance parameters in the Properties palette for all of the selected Sheets at one time.
If you know Dynamo, you could probably create a graph that would reset the values for all Sheets in a project, if your template file has a lot of pre-created Sheets and you would rather not have to select all the Sheets.
David Koch
Blog | LinkedIn
Nachricht 5 von 12
andrewsmith20
Thank you I had some sheets that were hiding and they had the instances I needed removed. Deleted those and they removed themselves from the document.
THANKS!
Nachricht 6 von 12
Create a Schedule, include the Parameter Field, untick itemize and then delete value shown.
Nachricht 7 von 12
David_W_Koch
@andrewsmith20
Here is a Dynamo graph, done in Revit 2020/Dynamo 2.3.0, that will, with the default settings, reset the values for Approved By, Designed By, Checked By and Drawn By to the "factory default values" (Approver, Designer, Checker and Author, respectively).  The replacement values are set up as "Inputs", so you can open the graph in Dynamo Player and edit those values to something else, if that is desired for a specific project file (or template file).
The graph was made with all out-of-the-box nodes.  Here is an image of the graph, for anyone who would like to put together the graph themselves:
David Koch
Blog | LinkedIn
Nachricht 8 von 12
andrewsmith20
This is awesome! thank you!
Nachricht 9 von 12
David_W_Koch
Just noticed that I managed to get Drawn By and Checked By in the wrong order in Dynamo Player (based on how they show in Properties).  The version attached here fixes that.  Here is what it looks like in Dynamo Player:
2-3-0_Change Sheet Credit Vaules for All Sheets_In Dynamo Player_2022-01-06.png
David Koch
Blog | LinkedIn
Nachricht 10 von 12
David_W_Koch
And, apparently, I cannot spell Values.  Or I have Dyslexic fingers.  I will leave fixing that to whomever chooses to download the files.
David Koch
Blog | LinkedIn
Nachricht 11 von 12
Dynamo?  Why? Seems like a sledgehammer when a hammer will do. That is, a Sheet List.
Nachricht 12 von 12
David_W_Koch
als Antwort auf: barthbradley
If you ever only need to do this once, then creating the Dynamo graph from scratch would probably take longer.  Unless you can get someone else, who may be tired of assigning people to BIM 360 projects and needed a change of pace to do it for you.  :zwinkerndes_Gesicht:
David Koch
Blog | LinkedIn
