Announcements
Community notifications may experience intermittent interruptions between 10–12 November during scheduled maintenance. We appreciate your patience.
Nested families visible when Hosted family visibility hidden
armanhosseini
armanhosseini
I am creating a bathroom family, which includes two levels of nested families. Level 1 is the individual plumbing fixtures (toilet, sink etc). Level 2 is a linear array of these families (to avoid conflicts with array groups). The level 2 array families are hosted into my Host family.
The Level 1 families are shared.
Here's the issue... within the Host family, when I toggle visibility of the Level 2 array family, the individual Level 1 fixtures are still visible.
Is there a way to toggle visibility of the Level 2 array family, as well as it nested Level 1 fixture families?
Thanks!
Depends on how are you are controlling visibility.  Post the Family.
armanhosseini
With a yes/no visibility parameter, linked to the Level2 Array family. Does that help clarify?
That's not what I meant.  Can you post the family?
armanhosseini
See attached example. I set this model up so that either the Left or the Right row of toilets are visible at a time. While one of the array families are indeed hidden, its nested toilet families are still visible.
The issue is resolved when the toilet families are not Shared. However, I'd like to keep them Shared if at all possible.
Thanks!
Looks like all you need to do it carry forth a visibility parameter for the geometry that you want to hide upstream.  In other words, associate Visibility Parameters at each level of Nesting.  Or am I crazy nuts confused here?  he, he.
Thanks!
Because Level 1 family is shared so they are independent from the Level 2 array visibility.  What you can do is add a Visibility parameter to the Level 1 family and associate it with a Visibility parameter of the level 2 family.
