Door schedule
5 REPLIES 5
411 Views, 5 Replies
Door schedule
Hi everybody,
first of all sorry for my English, I try to be more clear possible.
I have a problem with some parameters that don't appear on the door schedule. I attach two screenshot.
The first one is ok, no problem, in the schedule I can see the parameters I need.
In the second screenshot we see, for example, Materials and finitures. I can't add  and see these parameters in the schedule. Why?
I need to create other parameters? So it's a repetition... Can you explain some smart solution?
Thank you
Labels (2)
5 REPLIES 5
Not following. Are you doing at Material Takeoff Schedule?
Do you understand the Material and Finish Parameters in your 1st Screenshot are Text-Type Instance Parameter -- not Material-Type Parameters?
The 2nd Screenshot show Material-Type Parameters Grouped under Materials and Finishes header.
in reply to: barthbradley
no, i'm doing door schedule, but the parameters in the second picture (for exemple the ones named "poignée, panneau, ...") don't appear in the schedule.
Those are Material Parameters that are reported through a Material Take Off Schedule.
FWIW:
Thank you. As they are inside the doors properties, there are no way to add them in the schedule door? Do I need to create new parameters?
Make them Shared Parameters.
Forma Design Contest
