- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Evening everyone,
I've been running into an issue with aligning a door panel family in place within a door family. For starters, my idea was to create a door panel family that contains all different panel styles (flush, 1 panel, 2 panel, glass lite etc) that could then be loaded into the door family that only contains the door opening and frame. This way, our Revit model would have minimal door families, and lots of sub-types within the door family itself. I've essentially used this PDF I was referenced to for bringing in the door panel family, so that it snaps to a reference line tied to the door width that could also swing on an angle parameter. The door panel width/height/thickness is then tied to the door family itself. The panel "style" is then controlled by a label parameter so people can change the panel style as needed in each project.
https://forums.autodesk.com/autodesk/attachments/autodesk/133/84518/1/door%20swing1.pdf
One thing I could not figure out is how to get Revit to allow me to do what the PDF tutorial shows is place and snap the door panel family by it's end point. Every time I load the family, and attempt to place it on the reference line, it will only allow me to place by the midpoint.
Therein lies the next problem. Since I could not get this to work correctly, I attempted to snap/lock (tried to set/lock a 0" dimension parameter also) the door panel family on the reference line. I first tried snapping it to the end of the reference line, and then also tried doing an EQ dimension string to the center of the panel family within the reference line. But the issue I run into here is that when I change the panel style, the panel breaks its 0" (or EQ) alignments even though the panel family is set up to replace it's geometry in the same exact place no matter the panel type (or "style"). I was under the impression I was locking/snapping these in place using the left/center/right reference planes nested in the door panel family, but when the panel style changes, the dimensions that were originally aligned completely shift from what they were originally aligned to. For the life of me, I can not figure out why it's doing this.
One other wildcard to this is that the snapping seemed to work just fine when the door family was only a single door, but when I started to do a double door and a bifold door, things quickly went awry.
I've attached the door family with the nested door panel family within it for reference. I also attached a few screen shots of what happens when I change the door panel family within the overall door family. I know this is a bit of a doozie, but any help or insight would be greatly appreciated.
