Notice: Upload of PDF documents is currently unavailable across the Community due to an ongoing issue.
Door Frame Setback
Door Frame Setback
Door Frame Setback
I have a 4 panel sliding door (2 panels to slide each direction) that will stack beyond the opening--duel parallel track at top. Is there a way to get the attached family to offset/setback so that the doors appear at the face of the wall in plan? Currently they appear in the opening but I want them to exist outside the opening. My entire opening will be clear of door panels. Thank you.
constantin.stroescu
you have to create some extra parameters of offset.....anyway , the family  has to be reworked....I've made a quick example ...it has still to be verified...(Revit2017 version)
Constantin Stroescu
constantin.stroescu
Constantin Stroescu
The easiest way is create the panels as another  family, nested in the door family, then you can create a single parameter to constrain the setback distance very easily.
Here is a quick example sing your door as the nested family.
Thank you. I will try these options and see what works best. I am still learning how to create door and window families.
