door family not cutting through my unified wall
ahawkinsPMFUA
Message 1 of 8
ahawkinsPMFUA
I have a door family that I want to cut through a wall that was 2 walls now joined together..
It cuts through the first but the second wall it will not cut through
Both walls are the same height, definately joined but still the door will not cut
Anything I am doing wrong? thanks
Replies (7)
Message 2 of 8
Sean_Page
How far apart are the walls? If they are too far apart it will not cut the second wall.
Sean Page, AIA, NCARB, LEED AP
Senionr Partner, Computational Designer, Architect
Message 3 of 8
Are you using a void instead of a cut opening in the door family?
Message 4 of 8
imankassab2015
Edit the door family and check if the the door when it is Loadable is cut by void to cut through double walls ...
Message 5 of 8
ahawkinsPMFUA
there is no space between them
Message 6 of 8
ahawkinsPMFUA
by cut opening
Message 7 of 8
ahawkinsPMFUA
This is the condition I have. It will not cut the internal wall
Message 8 of 8
Looks like it's cutting through all the walls to me. Go to 3D View and isolate all the Walls in the View. Do they have all have openings cut all the way through them where the Door Families are placed?  If so, then you must be seeing something else in Plan View.  Maybe View Phase Filter related. Set the Plan View to Show Complete.
