Relate boolean YES/NO parameters
sebas_alva_g
Message 1 of 8
sebas_alva_g
Hi!
I am modeling a table family and would like that when one parameter is visible (with top chairs), the other one goes invisible (no top chairs), and vice-versa. May you have a solution, please?
Thanks!
Replies (7)
Message 2 of 8
Edited: Use formula for no top chair parameter:
not (with top chairs)
https://www.revitforum.org/forum/revit-all-flavors/tutorials-tips-tricks/1126-revit-formulas-for-eve...
Message 3 of 8
sebas_alva_g
Thanks! Something is not working. I tried several options with parenthesis and brackets. Do you know the correct one please?
Message 4 of 8
GaryOrrMBI
=not(with top chairs)
-G
Gary J. Orr
GaryOrrMBI (MBI Companies 2014-Current)
aka (past user names):
Gary_J_Orr (GOMO Stuff 2008-2014);
OrrG (Forum Studio 2005-2008);
Gary J. Orr (LHB Inc 2002-2005);
Orr, Gary J. (Gossen Livingston 1997-2002)
Message 5 of 8
sebas_alva_g
that made it thank you!
Message 6 of 8
sebas_alva_g
And what about the opposite, having a parameter checked automatically when another one is checked, for example, when "with top chairs" is checked, have "top clearance" also checked automatically? "Yes" did not make it
Message 7 of 8
sebas_alva_g
Just making it equal solved it! Thanks
Message 8 of 8
Alfredo_Medina
If you just make types for each configuration, you won't need formulas. Simply make the visibility parameter as Type parameters, and check the correspondent option for each possible configuration of the table.
