Hi
What method to do As shown Domed roof Make.
As it is difficult to explain by words the steps in order to obtain the mass, I made a record using Autodesk Project Chronicle (Dome Mass):
https://chronicle.autodesk.com/Main/Details/f6149af5-9dd6-4e80-a31c-f199a7854f35
Constantin Stroescu
Hi
Really thanks for your kind
But the more I make a pattern on the dome Is rotated by a small angle.
After you apply a pattern , play a little with the parameters: Offset, Belt Measurement and those from Pattern Application :Indent 1 and Indent 2 , etc.....
Constantin Stroescu
hi
Very Thank you.
I didn't mention Grid Rotation ...in your case this must be the problem....but I figure you already discoverded it ..usualy it is a align problem , that's what I said in my previous post...
Constantin Stroescu
