Greetings,
We have a central model that has several worksets and links. When we open the model all the workesets are closed. So I close the model, open the model with the open options and select All. The model opens with all the worksets open. I tried to save the model locally and centrall but the next time I go into the model the worksets are closed. I would like all the worksets to be open by default. Can anyone shed any light on why this might be happening?
This is for Revit 2014 (BDS) Build 20130709_2115(x64) UR1
Craig
Hello and Welcome to the Discussion!
It sounds like an interesting issue - I was unable to recreate it.
I created a central model, closed all of the created worksheets and as I saved it I went to the options (image attached) and set the Open worksets default: to last Viewed.
When I opened the model all of the worksheets were closed.
I opened them all and sync'd to the central, then closed and reopened - but the worksheets were open. How they are kept at close I am not sure.
Even after opening them with them closed - have you gone to the collaborate tab or the worksharing shortcut on the status bar and just open them? Instead of closing and opening and specifying what is open? Just a thought...
LD
