docking problem
docking problem
konetarchitecture
Message 1 of 50
docking problem
konetarchitecture
I just opened two separate projects in Revit Architecture 2014 and the Properties window and the Project Browser Window will not dock. When I double click on the top tab of each one, it will expand in width to the full width of my screen. What happened? I recently upgraded from 2013 to 2014. Is this a 2014 glitch??? Please help.
Replies (49)
Message 41 of 50
Ken,
You misunderstood what Lisa meant.  What she meant is you have to carefully see the vertical ghost line before you let it go.  The horizontal ghost line shows up first and is dominant.  Takes a little practice and yes patient to get the hand of it.  Works great now, I can snap it easy and quick.  Just move the window pallet from the left side slowly into the main window and you'll see the vertical ghost line, then snap it in.  Easy!  Thanks Lisa!
Message 42 of 50
Yeah took me a while to realise the dock does not attach to the left of the screen.
Message 43 of 50
Hi.
Your answer was really helpful.
Thank you!
Message 44 of 50
Thank you romeroj1204!!  This was driving me crazy!!
thanks
Anna
Message 45 of 50
Hey Alisder,
I have a similar setup, model space on one monitor and project browser/properties window on second monitor. For some or other reason when I start Revit the project browser and properties window will not respond to any input, it takes a few minutes before they become active. Once active all is fine.
Do you have any suggestions?
Thanks in advance.
Leon
Message 46 of 50
The palettes will dock at the side rather than the top if the cursor is positioned on the side as you drag the window. See
https://knowledge.autodesk.com/support/revit-products/getting-started/caas/CloudHelp/cloudhelp/2017/...
Message 47 of 50
very difficult to dock properties and system browser windows....:(
Message 48 of 50
lydiasambath
Observer
Observer
Thanks for the solution... Worked
Message 49 of 50
p.m
Good Morning: Any solution to this? This is an ongoing nightmare, which is compounded by all the other Revit issues. As usual, with Revit, all it takes is one dumb feature to shut-down progress and this is one of the dumbest. Why should we have to 'finagle' something as critical as the Properties and Project Browser?  Get-A-Grip, Autodesk.
Message 50 of 50
2021 still having this issue. Thanks for the tip after spending a long time trying to fix this I used your suggestion to turn the second monitor off and I was able to dock to the left.
Thanks!
