Docking Modify tab to a side panel
8 REPLIES 8
Message 1 of 9
tj6TCQ5
1731 Views, 8 Replies
I was wondering if there is a better way to permanently dock the modify tab to a side panel. I use this tab so often but revit frequently changes tabs through various actions but I always need the geometry, modify, and measure commands and wish I didn't have to change to that tab so often. I know you can undock the panels from the tab but then they just float over my windows and I have to move them again.
Is it possible to dock these commands to the bottom or side?
Tags (4)
Labels (4)
8 REPLIES 8
Message 2 of 9
in reply to: tj6TCQ5
Message 3 of 9
PavelAnd
Hi @tj6TCQ5. You can add your favourite commands to the quick access toolbar!
Best regards, Pavel Plotitsyn.
Message 4 of 9
I'm thinking this may be of interest to you:
https://help.autodesk.com/view/RVT/2020/ENU/?guid=GUID-C25E7343-0E12-4578-BB1F-77E4551109CA
Read the part under "Tab Switching Behavior".
Message 5 of 9
tj6TCQ5
in reply to: barthbradley
Not quite, I would like to dock the modify tab permanently to the right side of the screen. Don't mind the behavior of the tabs when in other commands but many times when framing or placing walls, I have to switch the tabs back and forth to complete what I'm doing. Trim, extend, and fillet are extremely useful to me in and out of editing sketches and profiles. There are at least 14 commands I use all the time from the tab, and adding them all to the quick access menu seems a little excessive. I'd rather have the whole tab docked to the side of the screen.
Message 6 of 9
What do you mean by: "I have to switch the tabs back and forth to complete what I'm doing".
Message 7 of 9
This information about noun-verb vs verb-noun selection may also be useful to you...
https://www.cad-notes.com/revit-basic-tip-selecting-objects/#:~:text=Revit%20allows%20you%20to%20sel....
Message 8 of 9
bill_gilliss
You maybe remember what AutoCAD looked like when darn near anything could be a floating or docked tool palette. I think this is the litter that the Ribbon was brought in to tidy up, in both programs. That said, I feel your pain.
Message 9 of 9
twool
Did you ever find a viable solution to lock the modify tab in a location?  We have so many add-ins built into our Revit tab template that I cannot uncheck, and the modify tab keeps going back to the far right, sometimes even hiding under the pull-down as there is no more room.  It is simply annoying.  I have to click CTRL and move it back to the beginning.  Over the course of my day the modify tabs keeps moving to the right. @Anonymous, please fix this.
Forma Design Contest
