Divided Parts Name into IFC
marialsantosU3V9F
marialsantosU3V9F
I have used the function Create Partes so I can separate the layers of an wall and see then in the IFC file as BuildingElementPart. But when I export and open in an IFC viewer, the name of the layer is a code that I don't know where it came from. How do I change the name of the Divided Part so in the IFC viewer the name of the layer is the Material?
vitorbortoncello
I don't know what code appears for you, but i believe it can be costumize in IFC parameters
A resposta te ajudou? Não esqueça de curtir e aceitar como solução!
Vitor Bortoncello | Arquiteto | BIM Manager
dAutodesk Certified Professional
