- Mute
- Permalink
- Report
How do I display ONLY demolished structures?
In the current construction, I have floors, with slopes and different nooks, bordered by walls, various plinths protrude from the floor. Part of the space will be demolished and new structures will be created there. I use only two phases - existing and new. Some elements are demolished whole (demolition phase set to "new state"), some parts of the floor is cutted through the void family. Phases work, show existing + demolished is displayed correctly, show existing + new too, show only new I see correctly too .
But I need to show JUST demolished elements, hide everything else. And this is where I came across it strangely. The element that is completely demolished is displayed correctly (wall, floor, beam, whatever). But if I'm demolishing only part of the element by the void family, that's the problem. The demolished part of the wall is still displayed correctly. But not the floor. I can't see the demolished part of the floor. Even if the wall and the floor are trimmed by the same void family, the relevant part of the wall will appear in the "cut only" view, but the floor will not.
this is what it looks like Existing + Demolition, that's fine
but only the Demolition phase turns out like this:
just demolished - floor cuts missing
So no cutouts in the floor are visible.
What am I doing wrong so that the cutouts in the floors don't show up ??
