Dimensions synchronization between Views
syama2001
Message 1 of 34
syama2001
Hi, i need to synchronize all dimensions in my project with at least copied View (with the possibility to change Stages on each View Separately). It’s bad that in copied view you can synchronize walls and etc. but can’t synchronize dimensions. I tried to create a Dynamo script but it turned out being super complicated to make well working script. Can you please help me? Thank you
Replies (33)
Message 2 of 34
Simon_Weel
What do you mean by synchronize all dimensions?
Message 3 of 34
azad.Nanva
screenshot or something for more understanding?
Message 4 of 34
syama2001
I want dimensions i draw in main View to appear in copied View
Message 5 of 34
syama2001
When i draw dimension in View #1 (for example) it doesn’t appear in View #1 copy
Message 6 of 34
Create dependent views from main view.
Message 7 of 34
syama2001
It’s not working. Dependent View only duplicates walls and etc. But not dimensions
Message 8 of 34
azad.Nanva
duplicate the views it doesn't mean duplicate the elements like wall,you can make the model group of your models and then make the Attached details group to model.
Message 9 of 34
Simon_Weel
Then it's not a Dependent View.
Message 10 of 34
Dependent views do show all annotation from the master view. That's why they are named dependent views.
Message 11 of 34
syama2001
Sorry, I didn't get what you are saying. I am not duplicating walls. Let me show you. I have a view, i copy it with dependence. But when i draw dimention (it's left one on my screen) it doesn't appear on the copied View
Message 12 of 34
syama2001
How do i make a dependent View so it also creates dimention when i draw it on the main view?
Message 13 of 34
syama2001
syama2001_0-1729538201040.pngSo i only draw the left dimetion and it didn't appear on the coppied View
Message 14 of 34
It should if it is indeed a dependent view.  I can't read Russian so can you point out and translate the file name of of both views?
Message 15 of 34
syama2001
As i know, dimensions are not copiing themselves to copied View when i draw it. Уровень 1 = View 1, View 1 COpy 1 = Уровень 1 копия 1
Message 16 of 34
You duplicated view.  There are three options when duplicating a view, you need to choose duplicate view as dependent.
Message 17 of 34
syama2001
I do duplicate view as dependent. It doesn't help with synchronizing drawing dimensions. You can check it yourself. I use revit 2024
Message 18 of 34
syama2001
Guys, my bad. I forgot to say. I need thoese 2 Views to be not dependent. Because when they are. I can't set different Stages on thoese Views! Sorry for not mentioning it before, i compleatly forgot about it
Message 19 of 34
syama2001
I made a video for you to understand my problem. I can't make dependend View, but with the possibility to set different Stages
(view in My Videos)
Message 20 of 34
Simon_Weel
