Dimensioning curved gridlines
Message 1 of 10
I have curved grid lines. I have been able to place a radius dimension on the innermost grid. Rather than place a radius dimension on each, I'd like to use an offset - dimensioning the space between the lines. Revit does not seem to let me do this. Am I missing something? I could understand if it's because it's curved, but the distance between the 2 is always the same, it would just have to find the perpendicular.Seems to be that "alined" dimensions should work, but I've also tried linear with no luck.
Thanks!
Replies (9)
Message 2 of 10
constantin.stroescu
You can do it either dimensioning the Arc Length or the chorde using Aligned Dimensions ( in this case you have to select the intersection points using TAB)
https://screencast.autodesk.com/Main/Details/78c6207c-6c23-4392-a507-a97f84c5f432
Constantin Stroescu
Message 3 of 10
It seems I wasn't clear enough with my question: I'd like to dimension the offset between 2 curved grid lines. Using your example, if there were a curved 'B' grid, say 5'-0" off the 'A' grid, it won't allow me to dimension from A to B. Any ideas on this?
Your example wil probably still come in useful for this project though!
Message 4 of 10
L.Maas
The basic problem is that when you have one or more curved lines the distance betwen the two lines will vary depending on the position of measurement. You only will have constant distances in 'rare' occassions like two circles sharing the same center point.
You will see the same behaviour when you have two straight lines which are not parallel.
Louis
Please mention Revit version, especially when uploading Revit files.
Message 5 of 10
I've attached an image of what I'm trying to do to clairify, the curved grid lines share a centerpoint, and are always the same distance from each other. One is simply offset a distance from the other. I want to dimension that offset.
In the attached: Grid line 'C' has a radius of 73'-11" from the center point. Grid line 'B.9' has a radius of 78'-11" from the same center point. I simply want a dimension of 5'-0" between them at a perpendicular - which 2 concentric circles have, in the spot I marked red, but Revit won't let me do that.
Message 6 of 10
constantin.stroescu
There is indeed a problem with Aligned Dimensions at grids and reference planes intersection points- it seems, who knows why, that in this case did not work.
But:
  1. for horizontal and vertical can be used the  Linear Dimension to snap points
  2. for other angles, a workaround can be done : draw a Detail Line or Model Line ( using SP - Snap Perpendicular to the second arc) , these lines allow Aligned Dimensions to snaping points ...Then, make invisible that line using a Filter of color...as shown in my screencast...
https://screencast.autodesk.com/Main/Details/b606d257-1d67-417b-8f8d-fdd1d704efea
Constantin Stroescu
Message 7 of 10
arunag
That was a good suggestion by Constantin . I have used reference planes instead of detail lines at the end of the grids to dimension the offset. As reference planes can be excluded from printing the filter step can be avoided.
Aruna
School of Architecture
Ramaiah Institute of Technology
Bangalore
Message 8 of 10
constantin.stroescu
STRANGE!
On my office computer both in 2015 and 2014 versions of Revit , Aligned Dimensions can be easy displayed by selecting snaping points.
I think there were some updates that solved the problem...
https://screencast.autodesk.com/main/details/b6c42a56-e7b7-4254-8e7e-b0a84b00cc56
Constantin Stroescu
Message 9 of 10
0323170020
New Member
New Member
i have the same problem, about dimensioning and griding curved plan
Message 10 of 10
arq_42
Draw a pair of short detail lines, tangent to the curved grids, and then dimension that pair of lines
¿Te resultó útil esta publicación? Dale "Me gusta".
¿Tu pregunta fue respondida correctamente? Haz clic en "ACEPTAR SOLUCIÓN".
