Building Story as custom Ifc parameter
bjorn.gustafsson2
bjorn.gustafsson2
Hi!
Is there any way of pushing only Building Stories to a custom Ifc parameter?
When I export to ifc I use a custom pset-file with lines like:
myLevelParameter      Text     Level
or
myLevelParameter      Text     Base Constraint
The problem is, if I have revit levels with Building Story unchecked I don't want those to be pushed to that parameter, but they are. Is there any alternative to Level and Base Constraint that only push Building Story names?
s_dziedzicBJXBG
  1. Create new parameters for the elements you need.
  2. Use a Dynamo script to check if the level is a building story, then apply SetParameterByName.
  3. Update your custom PSet file to include these new parameters.
