Dimension movin when cropped
3 REPLIES 3
Khadourwaseem
175 Views, 3 Replies
I have a problem, the dimensions between the grid lines move when I crop the view, all my grids are switched to 2d.
I can't figure how to turn this off, My dimensions should not move If I crop the view 1.png2.png
Tags (2)
3 REPLIES 3
RDAOU
in reply to: Khadourwaseem
@Khadourwaseem
Usually I would crop then place dimensions,,,Nonetheless, try the following see if it help
  • Edit type of dimension
  • Set Witness Lines control to "Fixed to Dimension Line"
What about uncropping, right-clicking Grids and Maximizing 3D Extents and then cropping again?   Still change to 2D?
Yeah, it still changes to 2d, the fix: I changed the 3d bottom point to be inside the crop region, and it stopped moving the dimensions.
I guess it's something of a fix
Forma Design Contest
Technology Administrators
