I have a problem, the dimensions between the grid lines move when I crop the view, all my grids are switched to 2d.
I can't figure how to turn this off, My dimensions should not move If I crop the view
Usually I would crop then place dimensions,,,Nonetheless, try the following see if it help
What about uncropping, right-clicking Grids and Maximizing 3D Extents and then cropping again? Still change to 2D?
Yeah, it still changes to 2d, the fix: I changed the 3d bottom point to be inside the crop region, and it stopped moving the dimensions.
I guess it's something of a fix
