Is there a way to make views visually different? Let's say its multiple iterations of the same design project, when "design options" just is too cumbersome and I make separate revit files, other than renaming the views distinctly, can the tabs be made visually different? in R2019? R2020?
Yes, I can drag and drop them to be more organized, and that may be the best answer.
Solved by MostafaElashmawy. Go to Solution.
So you want to colorize your tabs (for lack of a better example) based on different criteria?
Howard Munsell
This option is not available yet.
You can support this idea by voting to it.
https://forums.autodesk.com/t5/revit-ideas/categorize-tabbed-views/idc-p/8025420#M20785
Mostafa Elashmawy
I have to say I don't like the idea of colors...Being able to group the tabs of 1 design option set of views in one window and those of another design option in a separate window keeps all in order and easy to work with.
Below is laptop screenshot but at the office with 2x32" monitors I can easily work with main model + 2 design option sets...its more like having 3 sessions of Revit in one.
If you want some more options for tab view appearance bad enough to pay for it you can check out Parallax Apps Tabbed Views.
Steve Stafford
