Differentiated Tab Views
4 REPLIES 4
steve
533 Views, 4 Replies
Is there a way to make views visually different?    Let's say its multiple iterations of the same design project, when "design options" just is too cumbersome and I make separate revit files, other than renaming the views distinctly, can the tabs be made visually different?  in R2019?   R2020?
Yes, I can drag and drop them to be more organized, and that may be the best answer.
4 REPLIES 4
hmunsell
in reply to: steve
So you want to colorize your tabs (for lack of a better example) based on different criteria?
Howard Munsell
MostafaElashmawy
in reply to: steve
This option is not available yet.
You can support this idea by voting to it.
https://forums.autodesk.com/t5/revit-ideas/categorize-tabbed-views/idc-p/8025420#M20785
Mostafa Elashmawy
RDAOU
in reply to: steve
I have to say I don't like the idea of colors...Being able to group the tabs of 1 design option set of views in one window and those of another design option in a separate window keeps all in order and easy to work with.
Below is laptop screenshot but at the office with 2x32" monitors I can easily work with main model + 2 design option sets...its more like having 3 sessions of Revit in one.
SteveKStafford
in reply to: steve
If you want some more options for tab view appearance bad enough to pay for it you can check out Parallax Apps Tabbed Views.
Steve Stafford
Forma Design Contest
