Different Reference Planes for Plan and Sections
7 REPLIES 7
Message 1 of 8
2805 Views, 7 Replies
Hello. I want the reference planes that I am using in Plans not to appear in Sections or other view and vice-versa.
Ideas are mostly appreciated, thanks.
7 REPLIES 7
Message 2 of 8
BEE_Design
BEE_Design
Hi vcendoya,
Try turning off the Reference Plane Graphics in the Visibility/Graphics Overide (VV) Dialogue box. You'll find it in the Annotation Categories tab.
If you want this as a default to all the other sections / plans etc, then create a view template with it turned off and then apply the view template to all the other views. Can switch back to <none> view template after you have applied your settings.
Good Luck!
Best,
SY
Chasing BIM Architect ideal in HK with GeForce GTX 660 Ti, Intel(R) Core(TM) i7-3770 CPU @ 3.40GHz, 16.00 GB RAM, Mircrosoft Windows 10 Home.
Hi vcendoya,
Good Luck!
Best,
SY
Message 3 of 8
in reply to: BEE_Design
@BEE_Design
Thanks for your reply.
But for instance, if i want some reference planes in ground floor and I don´t want these to be shown on first floor,
and I want to create its own ones for that level, how do we achieve this?
If I turn them off in visibility grafics there will be all gone.
Thanks!
@BEE_Design
Thanks!
Message 4 of 8
EmptySaturnV
EmptySaturnV
If you are using Revit 2017, you can create a new subcategory for reference planes and hide/show the ones that you want in a view using your view settings.
Message 5 of 8
BEE_Design
BEE_Design
The visibility / graphics overrides (VV) applies to each view. So turning off the reference planes category in ground floor will not affect any other view.
Good luck,
Best
SY
Good luck,
Best
SY
Message 6 of 8
Create a scope box that does not extend to the other floors and assign it to the reference planes.
Message 7 of 8
aghis_no
aghis_no
For versions previous to 2017 you can use one or two specific s worksets that you may turn on and off depending the type of view you eye in. View templates may be a great help dealing with all the sections at once.
Hope it helps
Aghis
Hope it helps
Aghis
Message 8 of 8
I had the same doubt, and could solve it. What I did was, I selected all of the reference planes on my ground floor, and in the modify tab, i clicked on subcategory and changed from <None> to <Create new subcategory> So I created one called Ground Floor Reference Planes, and made sure all of my ground floor reference planes were set under this category. Then I changed to my first floor plan and opened up visibility graphics, and turned off the ground floor subcategry I created on the reference plane category. So all of them would disappear. I had to create a new subcategory for reference planes on first floor and that would work. Hope it was helpfull.
