Different Reference Planes for Plan and Sections
7 REPLIES 7
Message 1 of 8
2730 Views, 7 Replies
Hello. I want the reference planes that I am using in Plans not to appear in Sections or other view and vice-versa.
Ideas are mostly appreciated, thanks.
7 REPLIES 7
Message 2 of 8
BEE_Design
Hi vcendoya,
Try turning off the Reference Plane Graphics in the Visibility/Graphics Overide (VV) Dialogue box. You'll find it in the Annotation Categories tab.
If you want this as a default to all the other sections / plans etc, then create a view template with it turned off and then apply the view template to all the other views. Can switch back to <none> view template after you have applied your settings.
Good Luck!
Best,
SY
Chasing BIM Architect ideal in HK with GeForce GTX 660 Ti, Intel(R) Core(TM) i7-3770 CPU @ 3.40GHz, 16.00 GB RAM, Mircrosoft Windows 10 Home.
Message 3 of 8
in reply to: BEE_Design
@BEE_Design
Thanks for your reply.
But for instance, if i want some reference planes in ground floor and I don´t want these to be shown on first floor,
and I want to create its own ones for that level, how do we achieve this?
If I turn them off in visibility grafics there will be all gone.
Thanks!
Message 4 of 8
EmptySaturnV
If you are using Revit 2017, you can create a new subcategory for reference planes and hide/show the ones that you want in a view using your view settings.
Message 5 of 8
BEE_Design
The visibility / graphics overrides (VV) applies to each view. So turning off the reference planes category in ground floor will not affect any other view.
Good luck,
Best
SY
Message 6 of 8
Create a scope box that does not extend to the other floors and assign it to the reference planes.
Message 7 of 8
aghis_no
For versions previous to 2017 you can use one or two specific s worksets that you may turn on and off depending the type of view you eye in. View templates may be a great help dealing with all the sections at once.
Hope it helps
Aghis
Message 8 of 8
I had the same doubt, and could solve it. What I did was, I selected all of the reference planes on my ground floor, and in the modify tab, i clicked on subcategory and changed from <None> to <Create new subcategory> So I created one called Ground Floor Reference Planes, and made sure all of my ground floor reference planes were set under this category. Then I changed to my first floor plan and opened up visibility graphics, and turned off the ground floor subcategry I created on the reference plane category. So all of them would disappear. I had to create a new subcategory for reference planes on first floor and that would work. Hope it was helpfull.
