Different behaviors between 2016 and 2017 when importing SAT in Revit
Consultant Consultant
Message 1 of 18
When I import a SAT in a Revit 2016 conceptual mass, I can create a divided surface from the SAT geometry.  But when I import the same SAT in a Revit 2017 conceptual mass, it does not allow me to create a divided surface.
Revit 2016 steps:
- New Conceptual Mass
- Import CAD from Ribbon, choose SAT file and OK
- Hover cursor over SAT geometry and TAB to highlight
- Divide Surface using button on the Ribbon
Revit 2017 steps:
* The vital difference:  the SAT is imported in as a Mass, not an Import CAD
* Select the Mass and Divide Surface tool does not show
The test files for both versions are attached for you to experiment.
Replies (17)
Message 2 of 18
Viveka_CD
Hi @ToanDN
Thanks for sharing the files and for providing the information.
I've added these to the existing case and follow up for updates.
Message 3 of 18
Viveka_CD
Hi @ToanDN
I happened to check back on this case, and the team requested a journal as well.
The problem has been reproduced, but they are trying to analyze the behavior so a journal file is needed.
thanks,
Message 4 of 18
If they can reproduce the problem, why aren't they use their own journal?
Message 5 of 18
Viveka_CD
Hi @ToanDN
They have requested for your journal since they want to parse in detail for any discrepancies and do a valid comparison between both our journals.
Maybe its an API issue, but we have to wait to hear back from the team.
I will follow up with a upload link shortly - specifically for the sat issue.
Message 6 of 18
Sahay_R
@ToanDN - can we also have the SAT file to play with?
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
Message 7 of 18
Viveka_CD
@Sahay_R scroll up to see the SAT file and you are welcome to test with other forms as well.
Message 8 of 18
Sahay_R
Thanks @Viveka_CD - those are the SAT-in-RFA files. What I meant was the uninserted, unaltered, un-everythinged file.....I would like to mess it up in my own way!
Rina Sahay
Message 9 of 18
Just open that RFA and export it to SAT.  It was created that way.
Message 10 of 18
@Viveka_CD
Attached please find the journal files.
@Sahay_R
SAT file is here too.
Message 11 of 18
Sahay_R
2018 displays the same (mis)behavior.
FYI @Viveka_CD
However - and I'm sure @ToanDN has already noticed this - if you open the SAT-in-2016 family in 2017 - it behaves properly. Workaround, methinks?
Rina Sahay
Message 12 of 18
@Sahay_R  be quiet or the team will ask for your journal 😉
Message 13 of 18
Sahay_R
Ain't happenin', @ToanDN! You know better than to ask!!
Rina Sahay
Message 14 of 18
Viveka_CD
@ToanDN yes looks like it, @Sahay_R send us your journal.Smiley Very Happy I will add you to the existing folder if Toan is OK with it.
@Sahay_R you can try playing with FormIt to generate a sat file
Message 15 of 18
Viveka_CD
@ToanDN I've sent your files to the dev team and will follow up if we have any updates on this feature - Import/Export/Link SAT/SKP
Message 16 of 18
Sahay_R
In the meantime, just open the 2016 file in 2017 and 2018.
Rina Sahay
Message 17 of 18
J.Negrete
@Viveka_CD
What is the status of this problem? I've run into the same "misbehavior" in Revit 2019.1
Max 2019.1.1
Win10Pro x64. i9-7980XE, 128Gb Ram.
nVidia GTX 1080 Ti
Message 18 of 18
Viveka_CD
Hi @J.Negrete
Can you share a screencast of what you are experiencing?
There is an ongoing investigation of this import option, we would also like to test this further if you are willing to share your files to test.
I can send you a private upload link if you'd prefer. Let me know!
