Overhead Beam visibility in Electrical Plan
micah
micah
I am working on the electrical plan and I need to show the overhead beams in my plan because the LED's will be recessed in those beams.
The setting I normally use to show overhead beam is - Range Base Level - Upper Floor
        Range Top Level - Unbounded
        Underlay Orientation - Look up
The options for the structural beam in Visibility Graphics are also turned on.
Please advise me on how I can show the overhead beam.
Thank you!
Are the beams in your model or in a link file?
micah
Beams are in the model!!
@micah
The setting I normally use to show overhead beam is - Range Base Level - Upper Floor (current floor)
Also, make sure the view is set to Medium or Fine, or Structural beams category is set to Medium or Fine if you want to keep the view Coarse.
micah
Thank you so much @ToanDN!!
It worked 🙂 !!
anna8luka
Community Visitor
Community Visitor
hello
I have the same problem only with link structuel model, what can I do?
