02:40 AM
- Mute
- Permalink
- Report
For the company I work for I have to adjust the titleblocks. Nothing special, nothing fancy.
After I finished the adjustments and I want to make a plot or a pdf I notice the following problem.
There is a difference between the plotsize and the papersize. The plotsize is moved 5mm up and 5mm left according to the papersize.
I don't understand how this happened. I discussed the problem with my collegues they couldn't help me.
All the textblocks fit inside the boundries of the titleblock.
If we replace the titleblock with another the problem doesn't occur, So probably the error is something inside the titleblock.
Thank you for helping solving my problem.
