how i can display hidden footings below stairs ???!!!!!!
This is a solution if you are talking about the plan view:
You can select the floor plan view, set underlay to be foundation level and use line work ( line style "hidden"). Select edges of footings that are below stairs. After that, set underlay back to "none".
If you didn't define any levels below which may display those footings, just use detail lines and draw using line style "hidden" .
Andrej Ilić
phonetical: ændreɪ ilich
MSc Arch
Autodesk Expert Elite Alumni
Then just export with underlay on? No linework....
Andrej Ilić
MSc Arch
Revit has a tool for this: Show Hidden Lines.
You may also try switching disciplines.
No.
Structural Discipline with Show Hidden Lines by Discipline will show solid lines.
Structural Discipline with Show Hidden Lines for All will not show any lines.
That tool works on other elements, just not stairs.
Tested again. It works with View set to Structural Discipline, Show Hidden lines set to By Discipline. No need to use the Show Hidden Lines tool.
Just tested. Works for me. Portion of structural footing hidden by stairs, show as hidden lines.
R2018
[Structural by Discipline]
